system services ndmp password
(DEPRECATED)-Change the NDMP password for the node
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "vserver services ndmp generate-password " command. |
The system services ndmp password command is used to change the NDMP password for a node in the cluster. This command is not supported on Infinite Volumes.
-node {<nodename>|local}- Node-
The specific node for which the password is to be changed.
The following example is used to change the NDMP password for the node named node1:
cluster1::> system services ndmp password -node node1 Please enter password: Confirm password:
