job stop
Stop a job
The job stop command stops a running job. A stopped job cannot be resumed. Use the job pause command to pause a job so that you can later resume it. Use the job show command to view a list of running jobs.
-id <integer> - Job ID
The numeric ID of the job to stop. A job ID is a positive integer.
[-vserver <vserver name>] - Owning Vserver
Use this parameter to specify the name of the Vserver that owns the job.
The following example stops the job that has ID 101:
cluster1::> job stop -id 101
