security key-manager key show
Display Encryption Key IDs
This command displays the key IDs of the authentication keys (NSE-AK) and vserver keys (SVM-KEK) that are available in onboard key management. This command is not supported for an external key management configuration.
[-fields <fieldname>,…] -
If you specify the
[-detail ] -
If this parameter is specified, the command displays additional details about the key IDs.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If this parameter is specified, the command displays information only about key IDs that are located on the specified storage system.
[-key-store <Key Store>]- Key Store-
If this parameter is specified, the command displays information only about key IDs that are managed by the specified key management. For example, use
onboardfor onboard key management. [-key-id <text>]- Key Identifier-
If this parameter is specified, the command displays information only about the specified key IDs.
[-key-tag <text>]- Key Tag-
If this parameter is specified, the command displays information only about key IDs that have the specified key tags.
[-key-location <text>]- Key Location-
If this parameter is specified, the command displays information only about key IDs that are located on the specified key location. For example, use
local-clusterfor onboard key management. [-used-by <Key Usage Type>]- Used By-
If this parameter is specified, the command displays information only about key IDs that are associated with the specified application usage of the keys. For example, "NSE-AK" would display key IDs only for NSE drives.
[-restored {yes|no}]- Restored-
If this parameter is specified, the command displays information only about key IDs that have the specified value of restored keys. If restored is
yes, then the corresponding key is available (normal). If restored isno, use the security key-manager setup command to restore the key. See the man page for security key-manager setup for details.
The following example shows all keys stored in the onboard key manager:
cluster-1::> security key-manager key show Node: node1 Key Store: onboard Key ID Used By ---------------------------------------------------------------- -------- 000000000000000002000000000001001BC4C708E2A89A312E14B6CE6D4D49D4 NSE-AK 000000000000000002000000000001005E89099721F8817E65E3AEB68BE1BFCA NSE-AK 00000000000000000200000000000A0046DF92864D4CECE662B93BEB7F536610 SVM-KEK Node: node2 Key Store: onboard Key ID Used By ---------------------------------------------------------------- -------- 000000000000000002000000000001001BC4C708E2A89A312E14B6CE6D4D49D4 NSE-AK 000000000000000002000000000001005E89099721F8817E65E3AEB68BE1BFCA NSE-AK 00000000000000000200000000000A0046DF92864D4CECE662B93BEB7F536610 SVM-KEK 6 entries were displayed.
The following example shows a detailed view of all keys stored in the onboard key manager:
cluster-1::> security key-manager key show -detail
Node: node1
Key Store: onboard
Key ID Key Tag Used By Stored In Restored
- NSE-AK local-cluster yes
- SVM-KEK local-cluster yes
Node: node2
Key Store: onboard
