vserver cifs prepare-to-downgrade
Restore the CIFS Configurations to Earlier Release of Data ONTAP Version
The vserver cifs prepare-to-downgrade command restores the CIFS configurations for Data ONTAP based on the input parameter disable-feature-set.
-disable-feature-set <downgrade version>- Data ONTAP Version (privilege: advanced)-
This parameter specifies the Data ONTAP release for which the CIFS configurations are restored. The value can be one of the following:
8.3.1 - Restores the CIFS configurations for Data ONTAP release 8.3.1. These features include:
FPolicy "close with read" filters from FPolicy events.
CIFS server options
-guest-unix-userand-is-admin-users-mapped-to-root-enabled. -
CIFS security option
is-smb-encryption-required. -
Storage-Level Access Guard (SLAG) for qtrees.
CIFS share property
encrypt-data. -
8.3.2 - Restores the CIFS configurations for Data ONTAP release 8.3.2. These features include:
CIFS server option
-grant-unix-group-perms-to-others. -
9.0.0 - Restores the CIFS configurations for Data ONTAP release 9.0.0. These features include:
Disable CIFS multichannel feature and close all multichannel connections.
Delete all the name-mapping entries that have a hostname or an address field configured.
Terminate all SMB 3.1 client connections.
Terminate all client connections that have large MTU negotiated.
Remove the symlink property
no-strict-security. -
Remove all symlink pathmap entries with locality
freelink.
cluster1::*> vserver cifs prepare-to-downgrade -disable-feature-set 8.3.1
cluster1::*> vserver cifs prepare-to-downgrade -disable-feature-set 8.3.2
cluster1::*> vserver cifs prepare-to-downgrade -disable-feature-set 9.0.0
