volume efficiency revert-to
Reverts volume efficiency metadata
The volume efficiency revert-to command reverts the format of volume efficiency metadata for the volume to the given version of Data ONTAP. This command is not supported on FlexGroups.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
This specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name (privilege: advanced) -
This specifies the name of the volume for which volume efficiency metadata needs to be reverted.
-path </vol/volume>- Volume Path (privilege: advanced) } -
This specifies the volume path for which volume efficiency metadata needs to be reverted.
[-version <revert version>]- Revert to Version (privilege: advanced)-
Specifies the version of Data ONTAP to which the volume efficiency metadata needs to be formatted.
[-d, -delete {true|false}]- Delete Existing Metafile on Revert (privilege: advanced)-
If set to
true, this parameter specifies that the volume efficiency metadata be deleted instead of reverting its format. By default this parameter is set tofalse. [-c, -clean-up {true|false}]- Delete Previously Downgraded Metafiles (privilege: advanced)-
If set to
true, this parameter specifies that the volume efficiency metadata already reverted usingvolume efficiency revert-to ` be deleted. By default this parameter is set to `false. [-revert-adaptive-compression {true|false}]- Downgrade to minor version (privilege: advanced)-
If set to
true, this parameter Specifies that the volume efficiency metadata needs to be reverted to minor version of Data ONTAP. By default this parameter is set tofalse. [-check-snapshot {true|false}]- Revert ignore snapshots (privilege: advanced)-
If set to
false, this parameter specifies that the volume efficiency revert will not check for Snapshot copies created by previous releases of Data ONTAP. By default this parameter is set totrue.
The following examples reverts volume efficiency metadata on a volume named vol1 located in vserver vs1 to version 8.3.
cluster1::> volume efficiency revert-to -vserver vs1 -volume vol1 -version 8.3
cluster1::> volume efficiency revert-to -vserver vs1 -path /vol/vol1 -version 8.3
