volume qtree create
Create a new qtree
This command creates a qtree in the Vserver and volume you specify. You can create up to 4,994 qtrees per volume. This command is not supported on Infinite Volumes.
You can optionally specify the following attributes when creating a new qtree:
Security style
Opportunistic lock mode
UNIX permissions
Export Policy
-vserver <vserver name>- Vserver Name-
This specifies the name of the Vserver on which the volume containing the qtree belongs.
-volume <volume name>- Volume Name -
This specifies the name of the volume that will contain the qtree you are creating.
-qtree <qtree name>- Qtree Name-
This specifies the name of the qtree you are creating.
A qtree name cannot contain a forward slash (/). The qtree name cannot be more than 64 characters long.
-qtree-path <qtree path>- Actual (Non-Junction) Qtree Path } -
The qtree path argument in the format /vol/<volume name>/<qtree name> can be specified instead of specifying volume and qtree as separate arguments.
[-security-style <security style>]- Security Style-
This optionally specifies the security style for the qtree, which determines how access to the qtree is controlled. The supported values are
unix(for UNIX uid, gid and mode bits),ntfs(for CIFS ACLs), andmixed(for NFS and CIFS access). Theunifiedsecurity style, which applies only to Infinite Volumes, cannot be applied to a qtree. If you do not specify a security style for the qtree, it inherits the security style of its containing volume. [-oplock-mode {enable|disable}]- Oplock Mode-
This optionally specifies whether oplocks are enabled for the qtree. If you do not specify a value for this parameter, it inherits the oplock mode of its containing volume.
[-m, -unix-permissions <unix perm>]- Unix Permissions-
This optionally specifies the UNIX permissions for the qtree when the
-security-styleis set tounixormixed.You can specify UNIX permissions either as a four-digit octal value (for example, 0700) or in the style of the UNIX ls command (for example, ` -rwxr-x---` ). For information on UNIX permissions, see the UNIX or Linux documentation. If you do not specify UNIX permissions for the qtree, it inherits the UNIX permissions of its containing volume. [-export-policy <text>]- Export Policy-
This optional parameter specifies the name of the export policy associated with the qtree. For information on export policies, see the documentation for the vserver export-policy create command. If you do not specify a value for this parameter, it inherits the export policy of its containing volume.
The following example creates a qtree named qtree1. The Vserver name is vs0 and the volume containing the qtree is named vol1. The qtree has a mixed security style. Its other attributes are inherited from volume vol1.
cluster1::> volume qtree create -vserver vs0 -volume vol1 -qtree qtree1 -security-style mixed
The following example uses a 7G-compatible command to create the qtree.
cluster1::> vserver context vs0 vs0::> qtree create /vol/vol1/qtree1
