application snapshot show
Display a list of snapshots in an application or protection group.
This command displays snapshots in a given application or protection-group.
[-fields <fieldname>,…] -
Specifies fields that you want included in the output. You can use
-fields ?to display the available fields. - |
[-instance ]} -
Specifies the display of all available fields for each selected application.
[-vserver <vserver name>]- Vserver-
Selects snapshots belonging to vservers that match the parameter value.
[-application <text>]- Application-
Selects snapshots with application names that match the parameter value.
[-protection-group <text>]- Protection Group-
Selects snapshots with protection-groups that match the parameter value.
[-snapshot <snapshot name>]- Snapshot-
Selects snapshots with names that match the parameter value.
[-create-time <Date>]- Creation Time-
Selects snapshots with creation times that match the parameter value.
[-protection-group-uuid <UUID>]- Protection Group UUID-
Selects applications with protection-group unique identifiers that match the parameter value.
[-application-uuid <UUID>]- Application UUID-
Selects snapshots with application unique identifiers that match the parameter value.
[-snapshot-consistency-type {crash|application}]- Snapshot Consistency Type-
Selects snapshots with snapshot types that match the parameter value. The type field is used to differentiate between application consistent and crash consistent snapshots.
[-comment <text>]- Comment-
Selects snapshots with comments that match the parameter value.
[-is-partial {true|false}]- Partial Snapshot-
Selects snapshots with partial attributes that match the parameter value. The is-partial field is used to identify if a snapshot does not exist on all application components. A partial snapshot is still a valid snapshot. It does not exist on all application components because application components were added after the snapshot was created.
cluster1::> application snapshot show Vserver: vs Application: myapp1 Protection Group: myapp1 Snapshot Create Time Type ------------------------------- ------------------------ ----------- myapp1_snapshot_1 Wed Dec 31 16:16:40 2017 application
The example above displays all snapshots in an application protection-group in the cluster.
