system node image package external-device show
Display file listing on external device
The external-device show command displays files residing on the external storage device.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
This parameter selects the node that has files that are to be displayed on the external storage device. If this parameter is omitted, then the local node is the default node.
[-package <text>]- File Name (privilege: advanced)-
This parameter specifies the file for which the information is displayed.
[-device <usb0>]- Device (privilege: advanced)-
This parameter specifies the name of the external device. Currently, only usb0 is supported.
cluster1::> system image package external-device show Node Device Package File Name ------------------------ --------------- ------------------------------- node-01 usb0 image.tgz node-01 usb0 netboot.tgz 2 entries were displayed.
