system node image package show
Display software package information
The package show command displays details of the software packages residing on the storage controller.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects which node's packages are displayed. The local node is the default if this parameter is omitted.
[-package <text>] - Package File Name
This parameter specifies which package's information will be displayed.
cluster1::> system image package show
     Package
Node Repository Package File Name
node-01
     mroot
                image.tgz
1 entries were displayed.
