system script stop
Stops logging CLI I/O
The system script stop
command stops creating a record of your CLI session, if you started creating the record by using the system script start command. Use the system script show -this-session
yes
command to display files that are recording the current CLI session.
The following example shows how to stop creating a record of your CLI session.
cluster1::> system script stop
