system controller sp upgrade show
Display the Service Processor Upgrade Table
The system controller sp upgrade show command displays the following information about the service processor firmware of all the nodes in the cluster:
  • Node name
  • Is new firmware available?
  • Is autoupdate enabled?
  • Status of autoupdate
  • Health monitor status
To display more details, use the -instance parameter. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays detailed upgrade information of the service processor.
[-node {<nodename>|local}] - Node
Use this parameter to list the upgrade information of the service processor on the specified node.
[-new-fw-avail {true|false}] - New Firmware Available
Selects the information of the service processors which have new firmware available.
[-new-fw-version <text>] - New Firmware Version
Selects the information about service processors with the specified firmware version.
[-auto-update {true|false}] - Auto Update
Selects the information about service processors with the specified state.
[-auto-update-stat {installed|corrupt|updating|auto-updating|none}] - Auto Update Status
Selects the information about service processors with the specified auto update status.
[-auto-update-sttime <MM/DD/YYYY HH:MM:SS>] - Auto Update Start Time
Selects the information about service processors with the specified start time.
[-auto-update-entime <MM/DD/YYYY HH:MM:SS>] - Auto Update End Time
Selects the information about service processors with the specified end time.
[-auto-update-per <integer>] - Auto Update Percent Done
Selects the information about service processors with the specified auto update percentage completed.
[-auto-update-maxret <integer>] - Auto Update Maximum Retries
Selects the information about service processors with the specified maximum number of retries.
[-auto-update-curret <integer>] - Auto Update Current Retries
Selects the information about service processors with the specified number of current retries.
[-auto-update-prevstat {failed|passed}] - Previous AutoUpdate Status
Selects the information about service processors with the specified automatic update status.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example}] - Health Monitor Name
Selects the information about service processors with the specified monitor name.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Status
Selects the information about service processors with the specified health monitor status.
[-name <text>] - Display Name
Selects the information about service processors with the specified display name.
The example below displays service processor upgrade information for all nodes in the cluster:
cluster1::> system controller sp upgrade show
New   Firmware         Auto Update   Auto Update
Node  Available        Feature       Status          Status
node1 false            true          installed        ok
node2 false            true          installed        ok
2 entries were displayed.
The example below displays the detailed service processor upgrade information for a specific node:
cluster1::> system controller sp upgrade show -instance -node node1
Node: node1
     New Firmware Available: false
       New Firmware Version: Not Applicable
                Auto Update: true
         Auto Update Status: installed
     Auto Update Start Time: Thu Oct 20 20:06:03 2012 Etc/UTC
       Auto Update End Time: Thu Oct 20 20:09:19 2012 Etc/UTC
   Auto Update Percent Done: 0
Auto Update Maximum Retries: 5
Auto Update Current Retries: 0
 Previous AutoUpdate Status: passed
        Health Monitor Name: controller
                     Status: ok
               Display Name: SP Upgrade
