network tcpdump stop
Stop an active tcpdump trace
The network tcpdump stop command stops a running packet trace (via tcpdump) on a given network interface.
-node {<nodename>|local}- Node Name-
Use this parameter to specify the node on which the packet tracing must be stopped.
-port {<netport>|<ifgrp>}- Port-
Use this parameter to specify the network interface on which the packet tracing must be stopped.
The following example stops a packet trace on network interface "e0a" from node "node1":
cluster1::> network tcpdump stop -node node1 -port e0a
