system node internal-switch dump stat
Display onboard switch port statistics counter
The system node internal-switch dump stat command is used to display the counter information of the internal switch ports.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node <nodename>]- Node
Use this parameter to specify the node the switch resides on.
- [-switch-id <integer>]- Switch
Use this parameter to specify the switch id. For example, 1.
- [-port-id <integer>]- Port
Use this parameter to specify the port id. For example, 0.
- [-stat-id <text>]- Counter Name
Use this parameter to specify the counter name.
- [-valued <integer>]- Counter Value
Use this parameter to show the value of specified counter.
- [-port-name <text>]- Port Name
Use this parameter to specify the port name. For example, e0M.
The following example shows partial counter information of the internal switch 0 on Node1
cluster1::> system node internal-switch dump stat -node Node1 -switch-id 0 Port Port Name Counter Value ---- ---------------- ------------------- --------- Node: Node1 , Switch: 0 0 sw-wrench 1024ToMaxOctets 22480201 0 sw-wrench 128To255Octets 119552 0 sw-wrench 256To511Octets 345587 0 sw-wrench 512To1023Octets 1250437 0 sw-wrench 64Octets 803025
 PDFs
PDFs
