vserver iscsi show
Display a Vserver's iSCSI configuration
This command displays the current configuration of the iSCSI service.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Selects the iSCSI services for the Vserver that matches the parameter value.
[-target-name <text>]- Target Name-
Selects the iSCSI services with a target name that matches the parameter value.
[-target-alias <text>]- Target Alias-
Selects the iSCSI services with a target alias that matches the parameter value.
[-status-admin {down|up}]- Administrative Status-
Selects the iSCSI services with a configured status that matches the parameter value.
[-max-error-recovery-level <integer>]- Max Error Recovery Level (privilege: advanced)-
Selects the iSCSI services with a maximum error recovery level that matches the parameter value.
[-retain-timeout <integer>]- RFC3720 DefaultTime2Retain Value (in sec) (privilege: advanced)-
Selects the iSCSI services with a wait time that matches the parameter value. The wait time is the amount of time before active task reassignment is possible after an unexpected connection termination.
[-login-timeout <integer>]- Login Phase Duration (in sec) (privilege: advanced)-
Selects the iSCSI services with a login phase duration that matches the parameter value.
[-max-conn-per-session <integer>]- Max Connections per Session (privilege: advanced)-
Selects the iSCSI services with a maximum connection per session that matches the parameter value.
[-max-ios-per-session <integer>]- Max Commands per Session (privilege: advanced)-
Selects the iSCSI services with a maximum number of commands per session that matches the parameter value.
[-tcp-window-size <integer>]- TCP Receive Window Size (in bytes) (privilege: advanced)-
Selects the iSCSI services with a TCP receive window size (in bytes) that matches the parameter value.
cluster1::> vserver iscsi show
Target Target Status
Vserver Name Alias Admin
vs_1 iqn.1992-08.com.example:sn.c7c82a22bf9f11df83e5123478563412:vs.2
vs_1_alias up
1 entries were displayed.
cluster1::> vserver iscsi show -instance
Vserver: vs_1
Target Name: iqn.1992-08.com.example:sn.c7c82a22bf9f11df83e5123478563412:vs.2
The following is the output of the show command at the advanced privilege level:
Target Alias: vs_1_alias
Administrative Status: up
Displays the output of the show command at the admin privilege level.
cluster1::*> vserver iscsi show
vs_1_alias up
Displays the output of the show command at the advanced privilege level.
cluster1::*> vserver iscsi show -instance
Vserver: vs_1
Max Error Recovery Level: 0
DefaultTime2Retain Value (in sec): 20
Login Phase Duration (in sec): 20
Max Connections per Session: 4
Max I/O per Session: 128
TCP Window Size all Sessions (in bytes): 131400
Displays the detailed entries for all entries.
