vserver show-protocols
Show protocols for Vserver
The vserver show-protocols command displays the running protocols on a given Vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver-
If this parameter is specified, the command displays the allowed set of protocols for the specified Vserver.
[-protocol {nfs|cifs|fcp|iscsi|ndmp}]- Protocols-
If this optional parameter is specified, the command displays all the Vservers configured with the specified protocols.
The following example displays the protocols configured for Vserver vs1.
cluster1::> vserver show-protocols -vserver vs1 Vserver: vs1 Protocols: nfs, cifs
