event route show
(DEPRECATED)-Display event routes
This command has been deprecated. It may be removed from a future release of Data ONTAP. Instead, use the "event catalog" command set. |
This command displays information about event routes. Event routes describe which events generate notifications. A route specifies what to watch for, whom to notify, and what to do should a particular event occur. By default, the command displays the following information:
Message name of the event
Severity of the event
Destinations for event notifications
Frequency threshold for event notifications
Time threshold for event notifications
To display detailed information about a specific event route, run the command with the -message-name parameter, and specify the name of the message. The detailed view adds the following information:
Full description of the event
Action to be taken to address the event
You can specify additional parameters to limit output to the information that matches those parameters. For example, to display information only about events with a message name that begins with "raid", run the command with the -message-name raid* parameter. You can enter either a specific text string or a wildcard pattern.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-message-name <Message Name>]- Message Name-
Selects the event routes that match this parameter value.
[-severity {EMERGENCY|ALERT|ERROR|NOTICE|INFORMATIONAL|DEBUG}]- Severity-
Selects the event routes that match this parameter value. Valid values:
EMERGENCY - Disruption
ALERT - Single point of failure
ERROR - Degradation
NOTICE - Infromation
INFORMATIONAL - Information
DEBUG - Debug information
[-action <text>]- Corrective Action-
Selects the events that match this parameter value. This parameter is most useful when entered with wildcards. The "action" field describes what steps, if any, you must take to remedy the situation.
[-description <text>]- Description-
Selects the events that match this parameter value. This parameter is most useful when entered with wildcards. The "description" field describes why the event was encountered and what it means.
[-snmp-support {true|false}]- Supports SNMP trap-
[-destinations <Event Destination>,…]- Destinations-
Selects the event routes that match this parameter value. A destination is a list of email addresses, SNMP clients, and syslogs.
[-frequencythreshold <integer>]- Number of Drops Between Transmissions-
Selects the event routes that match this parameter value (number of events since previous notification).
[-timethreshold <integer>]- Dropping Interval (Seconds) Between Transmissions-
The following example displays information about all event routes:
cluster1::> event route show
Freq Time
Message Severity Destinations Threshd Threshd
admin.config.backup.
push.fail ERROR allevents,pager 5 120
admin.config.changed INFO allevents 0 0
admin.file.deleted INFO allevents 0 0
admin.login.failure INFO allevents 0 0
admin.software.
commit.failure ERROR criticals,allevents 0 0
admin.software.
commit.success INFO allevents 0 0
admin.software.
committing INFO allevents 0 0
admin.software.
installed INFO allevents 0 0
aggrcopy.dst.
autoRestrictMsg NOTICE allevents 0 0
aggrcopy.dst.
noMemory ERROR pager,admin 4 300
