network options load-balancing modify
PDF of this doc site
Creating your file...
Your file is ready
Modify load balancing algorithm
This command sets the state of geometric mean algorithm for load balancing
[-enable {true|false}]
- Geometric Mean Algorithm for load balancing-
Setting this parameter to
true
enables the geometric mean algorithm for load balancing. Setting it tofalse
disables the geometric mean algorithm for the cluster.
The following example will enable the geometric mean algorithm for load balancing. cluster1::> network options load-balancing modify -enable true The following example will disable the geometric mean algorithm for load balancing. cluster1::> network options load-balancing modify -enable false
