system controller config show
Display System Configuration Information
The system controller config show command displays system configuration information for the devices present in the controller. To display more details, use the -instance parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the nodes that match this parameter value.
[-device <text>] - Device
Selects the configuration information that matches the specified device.
[-slot <integer>] - Slot Number
Selects the configuration information that matches the specified slot.
[-subslot <integer>] - Subslot Number
Selects the configuration information that matches the specified subslot.
[-info <text>] - Device Info
Selects the configuration information that matches the specified device information.
The following example displays configuration information for slot 1 of the controller:
cluster1::> system controller config show -slot 1
Node: node1
Sub- Device/
Slot slot Information
   1    - NVRAM10 HSL
          Device Name:        Interconnect HBA: Generic OFED Provider
          Port Name:          ib1a
          Default GID:        fe80:0000:0000:0000:0000:0000:0000:0104
          Base LID:           0x104
          Active MTU:         8192
          Data Rate:          0 Gb/s (8X)
          Link State:         DOWN
          QSFP Vendor:        Amphenol
          QSFP Part Number:   112-00436+A0
          QSFP Type:          Passive Copper 1m ID:00
          QSFP Serial Number: APF16130066875
          QSFP Serial Number: APF16130066857
cluster1::>
