storage load show
Display I/O statistics to array LUNs, grouped by initiator port.
This command is obsolete. The storage load show command displays the load distribution of I/O on the cluster.
[-fields <fieldname>,…] -
If you specify the
[-switch ] -
The switch parameter adds switch information to the display.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Controller name-
The name of the clustered node for which information is being displayed.
[-initiator-port <text>]- Initiator Port-
The initiator port of the array LUN for which I/O stats are being displayed.
[-wwpn <text>]- Target Port WWPN-
The World Wide Port Name of the array LUN for which I/O stats are being displayed.
[-serialnumber <text>]- Serial Number-
The serial number of the array LUN for which I/O stats are being displayed.
[-lun <integer>]- LUN-
The array LUN for which I/O stats are being displayed.
[-pct-io <text>]- %I/O-
Percent of I/O bandwidth consumed by this array LUN.
[-io-blocks <integer>]- I/O (blocks)-
Number of I/O blocks transferred.
[-switch-port <text>]- Switch Port-
The initiator side switch port for this array LUN.
[-target-side-switch-port <text>]- Target Side Switch Port-
The target side switch port for this array LUN.
cluster1::> storage load show -switch
Initiator port: 0a connected to vnbr3850s4:7.
Target Side
LUN Serial # Target Port Switch Port %I/O I/O (blocks)
1 D600020C00D3 50060e80004291c0 vnbr3850s5:12 0 0
2 D600020C00D4 50060e80004291c0 vnbr3850s5:12 100 21
5 D600020C00EF 50060e80004291c0 vnbr3850s5:12 0 0
Initiator port: 0c connected to vnci9124s54:1-11.
Target Side
3 D600020C00D9 50060e80004291c2 vnci9124s54:1-22 42 8
4 D600020C00DA 50060e80004291c2 vnci9124s54:1-22 36 7
6 D600020C00F0 50060e80004291c2 vnci9124s54:1-22 15 3
Initiator port: 0a connected to vnbr3850s4:8.
Target Side
2 D600020C00D4 50060e80004291c0 vnbr3850s5:12 0 0
Target Side
6 D600020C00F0 50060e80004291c0 vnbr3850s5:12 100 31
Initiator port: 0c connected to vnci9124s54:1-12.
Target Side
1 D600020C00D3 50060e80004291c2 vnci9124s54:1-22 0 0
Target Side
3 D600020C00D9 50060e80004291c2 vnci9124s54:1-22 42 3
4 D600020C00DA 50060e80004291c2 vnci9124s54:1-22 42 3
12 entries were displayed.
