storage failover hwassist show
Display hwassist status
The storage failover hwassist show command displays information about hardware assisted takeover configurations. By default, the command displays the following information:
Node name.
Partner node name.
Whether hardware assisted takeover is enabled.
IP address on which the local node receives hardware assist alerts.
Port on which local node receives hardware assist alerts.
Hardware assist monitor status.
If the monitor is inactive, the reason it is inactive.
If the monitor is inactive, the corrective action to make it active.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the hwassist configurations that match this parameter value.
[-partner-name {<nodename>|local}]- Name of the Partner Node-
[-enabled {true|false}]- Local Hardware Assist Enabled-
[-local-status <text>]- Local Node's Hwassist Status-
Selects the hwassist configurations that match this parameter value (
activeorinactive). [-local-ip <text>]- IP Address on Which Local Node is Listening-
[-local-port <integer>]- Port on Which Local Node is Listening-
[-local-inactive <text>]- Local Node's Hwassist Inactive Status Reason-
[-local-action <text>]- Corrective Action on Local Node-
The following example displays the hardware assist information for the local node and its partner:
cluster1::> storage failover hwassist show
Node
ha1
Partner : ha2
Hwassist Enabled : true
Hwassist IP : 10.225.248.19
Hwassist Port : 4444
Monitor Status : active
Inactive Reason : -
Corrective Action : -
ha2
Partner : ha1
Hwassist IP : 10.225.248.21
Inactive Reason : -
