metrocluster modify
Modify MetroCluster configuration options
The metrocluster modify command modifies MetroCluster parameters for nodes in the MetroCluster configuration.
-auto-switchover-failure-domain <MetroCluster AUSO Failure Domain>- Cluster Level AUSO Option -
This parameter specifies configuration of the automatic switchover. Supported values are as follows:
auso-on-cluster-disaster - triggers an unplanned switchover if all nodes in a DR cluster are down.
auso-disabled - automatic switchover is disabled.
The default value is
auso-on-cluster-disaster. It is set to default value ifmetrolcuster configurecommand is issued.The auto-switchover failure domain is set to
auso-disabledif themetrocluster unconfigurecommand is issued.This setting only affects the local cluster where the command is run.
-node-name {<nodename>|local}- Node to Change the Option On } -
This parameter is used to specify the node in the cluster for which the parameter needs to be modified.
[-automatic-switchover-onfailure <true>]- Node Level AUSO Option (privilege: advanced) }-
This parameter is used to enable automatic switchover on failure on a node when it is disabled because of internal errors.Possible value for this field is true. This option is available in diag mode and should be used only when warning ems message comes. All the nodes in MCC configuration must have this option enabled (the default state) to enable automatic switchover on failure.
The following example shows the output of Metrocluster modification done on a node:
clusA::*> metrocluster modify -node-name clusA-01 -node-object-limit on
[Job 168] Job succeeded: Modify is successful
clusA::*> metrocluster modify -node-name clusA-01 -automatic-switchover-onfailure false
[Job 308] Job succeeded: Modify is successful
clusA::> metrocluster modify -auto-switchover-failure-domain auso-on-cluster-disaster
