system ha interconnect port show
Display the high-availability interconnect device port information
The system ha interconnect port show command displays the high-availability interconnect device port physical layer and link layer status information.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
Use this parameter to display all the fields from all nodes in the cluster.
 [-node {<nodename>|local}]- Node (privilege: advanced)-
Use this parameter to display all the fields from the specified node in the cluster.
 [-link-monitor {on|off}]- Link Monitor Detection (privilege: advanced)-
Selects the nodes that match this parameter value.
 [-port <integer>,…]- Port Number (privilege: advanced)-
 [-phy-layer-state {invalid|sleep|polling|disabled|port-configuration-testing|linkup|link-error-recovery|phytest|reserved}]- Physical Layer State (privilege: advanced)-
 [-link-layer-state {invalid|down|initialize|armed|active|reserved}]- Link Layer State (privilege: advanced)-
 [-phy-link-up-count <integer>,…]- Physical Link Up Count (privilege: advanced)-
Selects the nodes that match this parameter value. The value is total number of times the link on a given port is transitioned up.
 [-phy-link-down-count <integer>,…]- Physical Link Down Count (privilege: advanced)-
Selects the nodes that match this parameter value. The value is total number of times the link on a given port is transitioned down.
 [-is-active-link {true|false}]- Is the Link Active (privilege: advanced)-
truemeans the interconnect data channels are established on this link.
The following example displays the HA interconnect device port information on FAS8000 series nodes in the cluster:
cluster1::*> system ha interconnect port show
                               Physical  Link
                Link           Layer     Layer      Physical   Physical  Active
Node            Monitor  Port  State     State       Link Up  Link Down  Link
ic-f8040-01     on
                            0  linkup    active            1          0  true
                            1  linkup    active            1          0  false
ic-f8040-02     on
2 entries were displayed.
