storage shelf drawer show-slot
PDF of this doc site
Creating your file...
Display a map between bay number and drawer/slot number
The storage shelf drawer show-slot
command maps each drawer and slot number to the corresponding bay number.
[-fields <fieldname>,…]
Displays the specified fields in column style output.
[-instance ]
Displays all slot information.
[-shelf <text>]
- Shelf Name-
Displays the slots in the shelf that matches the specified shelf name.
[-bay <integer>]
- Bay Number-
Displays the slots that have the specified bay number.
[-node {<nodename>|local}]
- Node Name-
Displays the slots that are present for the specified node.
[-drawer <integer>]
- Drawer Number-
Displays the slots in the drawers that match the specified drawer number.
[-slot <integer>]
- Slot Number-
Displays the slots that match the specified slot number.
[-is-installed {yes|no}]
- Is Disk Installed-
Displays the slots that have a disk installed.
The following example displays the mapping from drawer and slot number to bay number:
cluster1::> storage shelf drawer show-slot Shelf Drawer Slot Bay Installed? ----- ------ ---- --- ---------- 2.5 1 0 0 yes 1 1 no 2 2 no 3 3 yes 4 4 no 5 5 no 6 6 yes 7 7 no 8 8 no 9 9 yes 10 10 no 11 11 no 2 0 12 yes 1 13 no 2 14 no 3 15 yes 4 16 no 5 17 no 6 18 yes 7 19 no 8 20 no 9 21 yes 10 22 no 11 23 no 3 0 24 yes 1 25 no 2 26 no 3 27 yes 4 28 no 5 29 no 6 30 yes 7 31 no 8 32 no 9 33 yes 10 34 no 11 35 no 4 0 36 yes 1 37 no 2 38 no 3 39 yes 4 40 yes 5 41 no 6 42 yes 7 43 no 8 44 no 9 45 yes 10 46 no 11 47 no 5 0 48 yes 1 49 no 2 50 no 3 51 yes 4 52 no 5 53 no 6 54 yes 7 55 no 8 56 no 9 57 yes 10 58 no 11 59 no 60 entries were displayed. cluster1::>
