system services ndmp service modify
Modify NDMP service configuration
The system services ndmp service modify command allows you to modify the NDMP service configurations for a node in the cluster. The following configuration can be modified:
NDMP Common Sessions
This command is not supported on Infinite Volumes.
- -node {<nodename>|local}- Node (privilege: advanced)
This specifies the node whose NDMP configuration is to be modified.
- [-common-sessions <integer>]- NDMP Common Sessions (privilege: advanced)
This optional parameter specifies the number of extra common NDMP sessions supported, in addition to the number of backup and restore sessions supported for a platform. The default value is 4 for all platforms. The number of backup and restore sessions are platform dependent. Increasing this parameter can make the storage system unresponsive.
The following example modifies the NDMP configuration on a node named node1. The configuration sets the NDMP Common Sessions to 16:
cluster1::> system services ndmp modify -node node1
     -common-sessions 16
 PDFs
PDFs
