security session limit application modify
Modify per-application session limit
This command allows modification of a per-application management session limit.
-interface {cli|ontapi}- Interface (privilege: advanced)-
The interface (CLI or ONTAPI) to which the limit applies.
-application <text>- Application (privilege: advanced)-
The specified application to which this limit applies. The limit with the application name
-default-is the limit used for any application without a specific configured limit. [-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)-
The maximum number of concurrent sessions allowed for this interface and application.
The following example illustrates modifying management session limits for some custom applications.
cluster1::*> security session limit application modify -interface ontapi -application custom* -max-active-limit 4 2 entries were modified.
