system controller config show-errors
PDF of this doc site
Creating your file...
Your file is ready
Display configuration errors
The system controller config show-errors
displays configuration errors.
node
description
To display more details, use the -instance parameter.
[-fields <fieldname>,…]
Selects the fields that you specify.
[-instance ]
Displays detailed information for all the PCI devices.
[-node {<nodename>|local}]
- Node-
Displays configuration errors on the specified node.
[-verbose <true>]
- Verbose Output?-
The
-verbose
parameter enables verbose mode, resulting in the display of more detailed output. [-description <text>]
- Error Description-
Displays the node with the specified configuration error.
The example below displays configuration errors on all the nodes in the cluster.
cluster1::> system controller config show-errors Configuration Info and Errors for Node: cluster1-01 ------------------------------------------------------------------------------ Chelsio T320E 2x10G NIC card (PN X1008A) in slot 1 is not supported on model FAS3210 Configuration Info and Errors for Node: cluster1-02 ------------------------------------------------------------------------------ PCI-E Dual 10/100/1000 Ethernet G20 card (PN X1039A) in slot 2 is not supported on model FAS3210 cluster1::> cluster1::> system controller config show-errors -verbose Configuration Info and Errors for Node: cluster1-01 ------------------------------------------------------------------------------ sysconfig: Card in slot 2 (7-1275-0008-46848) is not supported. sysconfig: slot 12 OK: X2067: Proprietary embedded SAS HBA cluster1::>
