security session limit request delete
Delete per-request session limit
This command allows deletion of a per-request management session limit.
-interface {cli|ontapi}- Interface (privilege: advanced)-
The interface (CLI or ONTAPI) to which the limit applies.
-request <text>- Request Name (privilege: advanced)-
The specified request to which this limit applies. The limit with the request name
-default-is the limit used for any request without a specific configured limit.
The following example illustrates deleting custom limits for that were configured for the volume commands and APIs.
cluster1::*> security session limit request delete -interface * -request volume* 4 entries were deleted.
