system controller flash-cache secure-erase show
Display the Flash Cache card status
The system controller flash-cache secure-erase show command displays the current Flash Cache device secure-erase status.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If this parameter is specified, only status information for the matching node is displayed.
[-slot <text>]- Slot-
If this parameter is specified, only status information for the matching slot is displayed. Slot can have a format of slot or slot-subslot.
[-device-state {ok|erasing|erased|failed|removed}]- Device State-
If this parameter is specified, only status information for the matching device-state is displayed.
The following example displays the current state of all the Flash Cache devices:
cluster1::> system controller flash-cache secure-erase show
Node Slot Device State
node1
6-1 ok
6-2 erasing
node2
6-1 erased
6-2 ok
4 entries were displayed.
