storage bridge remove
Remove a bridge from monitoring
The storage bridge remove enables you to remove FC-to-SAS bridges that were previously added for SNMP monitoring.
-name <text>- Bridge Name-
This parameter specifies the name of the bridge added for monitoring.
The following command removes 'ATTO_10.226.197.16' bridge from monitoring:
cluster1::> storage bridge remove -name ATTO_10.226.197.16
cluster1::> storage bridge show
Is Monitor
Bridge Symbolic Name Vendor Model Bridge WWN Monitored Status
ATTO_FibreBridge6500N_1
Bridge Number 16
Atto FibreBridge 6500N
2000001086603824 false -
ATTO_FibreBridge6500N_2
Not Set Atto FibreBridge 6500N
20000010866037e8 false -
ATTO_FibreBridge6500N_3
2000001086609e0e false -
ATTO_FibreBridge6500N_4
2000001086609c06 false -
4 entries were displayed.
