volume move target-aggr show
List target aggregates compatible for volume move
The volume move target-aggr show displays information about compatible target aggregates for the specified volume to be moved to.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name (Required field)-
Selects information about compatible target aggregates for volumes of the specified Vserver.
[-volume <volume name>]- Volume Name (Required field)-
Selects information about compatible target aggregates that have enough space for the specified volume.
[-aggregate <aggregate name>]- Aggregate Name-
Selects information about compatible target aggregates with the specified aggregate name (to which the volume might be moved).
[-tiering-policy {snapshot-only|none|backup}]- Volume Tiering Policy-
Selects information about compatible target aggregates with the specified destination tiering policy.
[-availsize {<integer>[KB|MB|GB|TB|PB]}]- Available size-
Selects information about compatible target aggregates that have the specified available size.
[-storagetype <text>]- Storage Type-
Selects information about compatible target aggregates with the specified storage type. Examples of storage types are “ATA”, ”BSAS”, “FCAL”, “LUN”, “SATA”, “SAS” and “SSD”.
The following example lists target aggregates compatible for moving a volume vol1 on a Vserver vs1.
cluster1::> volume move target-aggr show -vserver vs1 -volume vol1
Aggregate Name Available Size Storage Type
aggr1 113.5GB FCAL
aggr2 113.5GB FCAL
2 entries were displayed.
