storage raid-options show
Display RAID options
The storage raid-options show command displays information about all the RAID options in a cluster. The options are described in the storage raid-options manual page.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects information about all the RAID options on the specified node.
 [-name <text>]- Option Name-
Selects information about the RAID options that have the specified name.
 [-value <text>]- Option Value-
Selects information about all the RAID options that have the specified value.
 [-constraint <text>]- Option Constraint-
Selects information about all the RAID options that have the specified constraint. The 'constraint' field indicates the expected setting for a RAID option across both nodes of an HA pair. The possible values are:
none- no constraint on the value of this RAID option; nodes can have different values -
same_preferred- the same value should be used on both nodes of an HA pair, otherwise the next takeover may not function correctly -
same_required- the same value must be used on both nodes of an HA pair, otherwise the next takeover will not function correctly -
only_one- the same value should be used on both nodes of an HA pair. If the values are different and a takeover is in progress, the value of the RAID option on the node that is taking over will be used -
unknown- no information about constraints for this RAID option
The following example shows the raid scrub settings for a node named node1:
cluster1::> storage raid-options show -node node1 -name raid.scrub* Node Option Value Constraint -------- ------------------------------------- ------------ ----------- node1 raid.scrub.perf_impact low only_one node1 raid.scrub.schedule none 3 entries were displayed.
