storage aggregate offline
PDF of this doc site
Creating your file...
Your file is ready
Offline an aggregate
The storage aggregate offline
command takes an aggregate offline.
If you are taking a root aggregate offline, the node owning the aggregate must be in maintenance mode.
-aggregate <aggregate name>
- Aggregate-
The name of the aggregate to be taken offline.
The following example takes an aggregate named aggr1 offline:
cluster1::> storage aggregate offline -aggregate aggr1
