network routing-groups route show
(DEPRECATED)-Display static routes
This command has been deprecated and may be removed from a future version of Data ONTAP. Use the "network route" command set to configure routes instead. |
The network routing-groups route show command displays a group of static routes within one or more routing groups. You can view routes originating from specified servers, routes within specified routing groups, routes with specified gateways, and routes with a specified number of hops.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver Name-
Use this parameter to display the routes within the specified vserver.
[-routing-group <text>]- Routing Group-
Use this parameter to display the routes within the specified routing group.
[-destination <IP Address/Mask>]- Destination/Mask-
Use this parameter to diplay the routes with the specified destination IP address.The format for this value is: address, slash ("/"), mask. The example below has
0.0.0.0/0as a valid value for the -destination parameter. [-gateway <IP Address>]- Gateway-
Use this parameter to display the routes with the specified gateway.
[-metric <integer>]- Metric-
Use this parameter to display the routes with the specified metric.
[-address-family {ipv4|ipv6|ipv6z}]- Address Family-
Use this parameter to display the routes using the specified address family. Only IPv4 and IPv6 non-zoned addresses can be used for this parameter. IPv6z addresses should not be used.
The following example displays information about all routing groups.
cluster1::> network routing-groups route show
Routing
Server Group Destination Gateway Metric
node1 d192.0.2.165/24
0.0.0.0/0 10.61.208.1 20
node2 d192.0.2.166/24
2 entries were displayed.
