vserver cifs share access-control modify
Modify an access control list
The vserver cifs share access-control modify command modifies the permissions of a user or group in a CIFS share's ACL.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver containing the CIFS share whose ACL you want to modify.
-share <Share> - Share Name
This parameter specifies the name of the CIFS share whose ACL you want to modify.
-user-or-group <TextNoCase> - User/Group Name
This parameter specifies the user or group to modify. If you specify the user name, you must include the user's domain using the format "domain\username". The user-or-group parameter is case-insensitive text.
[-user-group-type {windows|unix-user|unix-group}] - User or Group Type
This parameter specifies the type of the us
