network tuning icmp6 show
PDF of this doc site
Creating your file...
Your file is ready
Show ICMPv6 tuning options
This command displays the current state of the ICMPv6 tuning options for the given node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
Displays all ICMPv6 tuning options.
[-node {<nodename>|local}]
- Node-
Specifies the node for which the ICMPv6 tuning options are displayed.
[-is-v6-redirect-accepted {true|false}]
- Accept redirects via ICMPv6-
Displays all entries that match the "is-v6-redirect-accepted" value.
[-redirect-v6-timeout <integer>]
- Maximum seconds for route redirect timeout-
Displays all the entries that match the "redirect-v6-timeout" value.
cluster1::> network tuning icmp6 show Accept Redirect Redirect Timeout Node ICMPv6 in Seconds --------- --------------- ---------------- node1 true 300
