The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network tuning icmp6 show
PDF of this doc site
Creating your file...
Your file is ready
Show ICMPv6 tuning options
This command displays the current state of the ICMPv6 tuning options for the given node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
Displays all ICMPv6 tuning options.
[-node {<nodename>|local}]
- Node-
Specifies the node for which the ICMPv6 tuning options are displayed.
[-is-v6-redirect-accepted {true|false}]
- Accept redirects via ICMPv6-
Displays all entries that match the "is-v6-redirect-accepted" value.
[-redirect-v6-timeout <integer>]
- Maximum seconds for route redirect timeout-
Displays all the entries that match the "redirect-v6-timeout" value.
[-tx-icmp6-err-limit <integer>]
- Maximum number of ICMPv6 error messages sent per second-
Displays all entries that match the "tx-icmp6-err-limit" value.
cluster1::> network tuning icmp6 show Accept Redirect Maximum ICMPv6 Error Redirect Timeout Node ICMPv6 Sends per Second in Seconds --------- --------------- -------------------- ---------------- node1 true 100 300
