      network tuning icmp6 show
Show ICMPv6 tuning options
This command displays the current state of the ICMPv6 tuning options for the given node.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
Displays all ICMPv6 tuning options.
- [-node {<nodename>|local}]- Node
Specifies the node for which the ICMPv6 tuning options are displayed.
- [-is-v6-redirect-accepted {true|false}]- Accept redirects via ICMPv6
Displays all entries that match the "is-v6-redirect-accepted" value.
- [-redirect-v6-timeout <integer>]- Maximum seconds for route redirect timeout
Displays all the entries that match the "redirect-v6-timeout" value.
- [-tx-icmp6-err-limit <integer>]- Maximum number of ICMPv6 error messages sent per second
Displays all entries that match the "tx-icmp6-err-limit" value.
cluster1::> network tuning icmp6 show
Accept Redirect Maximum ICMPv6 Error Redirect Timeout
Node      ICMPv6          Sends per Second     in Seconds
node1
          true            100                  300
 PDFs
PDFs
