      network tuning icmp6 show
Show ICMPv6 tuning options
This command displays the current state of the ICMPv6 tuning options for the given node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
Displays all ICMPv6 tuning options.
 [-node {<nodename>|local}]- Node-
Specifies the node for which the ICMPv6 tuning options are displayed.
 [-is-v6-redirect-accepted {true|false}]- Accept redirects via ICMPv6-
Displays all entries that match the "is-v6-redirect-accepted" value.
 [-redirect-v6-timeout <integer>]- Maximum seconds for route redirect timeout-
Displays all the entries that match the "redirect-v6-timeout" value.
 [-tx-icmp6-err-limit <integer>]- Maximum number of ICMPv6 error messages sent per second-
Displays all entries that match the "tx-icmp6-err-limit" value.
cluster1::> network tuning icmp6 show
Accept Redirect Maximum ICMPv6 Error Redirect Timeout
Node      ICMPv6          Sends per Second     in Seconds
node1
          true            100                  300
