network tuning icmp6 show
Show ICMPv6 tuning options
This command displays the current state of the ICMPv6 tuning options for the given node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
Displays all ICMPv6 tuning options.
[-node {<nodename>|local}]
- Node-
Specifies the node for which the ICMPv6 tuning options are displayed.
[-is-v6-redirect-accepted {true|false}]
- Accept redirects via ICMPv6-
Displays all entries that match the "is-v6-redirect-accepted" value.
[-redirect-v6-timeout <integer>]
- Maximum seconds for route redirect timeout-
Displays all the entries that match the "redirect-v6-timeout" value.
[-tx-icmp6-err-limit <integer>]
- Maximum number of ICMPv6 error messages sent per second-
Displays all entries that match the "tx-icmp6-err-limit" value.
cluster1::> network tuning icmp6 show Accept Redirect Maximum ICMPv6 Error Redirect Timeout Node ICMPv6 Sends per Second in Seconds --------- --------------- -------------------- ---------------- node1 true 100 300
