snapmirror set-options
Display/Set SnapMirror options
The snapmirror set-options command can be used to display or set snapmirror options. This command is not supported for Infinite Volume SnapMirror relationships.
[-dp-source-xfer-reserve-pct {0|25%|50%|75%|100%}]- Percentage Reserved for DP Source Transfers-
Specifies the percentage of maximum allowed concurrent transfers reserved for source DP transfers
[-xdp-source-xfer-reserve-pct {0|25%|50%|75%|100%}]- Percentage Reserved for XDP Source Transfers-
Specifies the percentage of maximum allowed concurrent transfers reserved for source XDP transfers
[-dp-destination-xfer-reserve-pct {0|25%|50%|75%|100%}]- Percentage Reserved for DP Destination Transfers-
Specifies the percentage of maximum allowed concurrent transfers reserved for destination DP transfers
[-xdp-destination-xfer-reserve-pct {0|25%|50%|75%|100%}]- Percentage Reserved for XDP Destination Transfers-
Specifies the percentage of maximum allowed concurrent transfers reserved for destination XDP transfers
The following example displays SnapMirror options:
cluster1::> snapmirror set-options
Percentage Reserved for DP Source Transfers: 0
Percentage Reserved for XDP Source Transfers: 0
Percentage Reserved for DP Destination Transfers: 0
Percentage Reserved for XDP Destination Transfers: 0
cluster1::> snapmirror set-options -dp-source-xfer-reserve-pct 25
-xdp-source-xfer-reserve-pct 50 -dp-destination-xfer
reserve-pct 0 -xdp-destination-xfer-reserve-pct 50
Percentage Reserved for DP Source Transfers: 25
Percentage Reserved for XDP Source Transfers: 50
Percentage Reserved for XDP Destination Transfers: 50
