snapmirror set-options
Display/Set SnapMirror options
The snapmirror set-options command can be used to display or set snapmirror options.
[-dp-source-xfer-reserve-pct {0|25%|50%|75%|100%}] - Percentage Reserved for DP Source Transfers
Specifies the percentage of maximum allowed concurrent transfers reserved for source DP transfers
[-xdp-source-xfer-reserve-pct {0|25%|50%|75%|100%}] - Percentage Reserved for XDP Source Transfers
Specifies the percentage of maximum allowed concurrent transfers reserved for source XDP transfers
[-dp-destination-xfer-reserve-pct {0|25%|50%|75%|100%}] - Percentage Reserved for DP Destination Transfers
Specifies the percentage of maximum allowed concurrent transfers reserved for destination DP transfers
[-xdp-destination-xfer-reserve-pct {0|25%|50%|75%|100%}] - Percentage Reserved for XDP Destination Transfers
Specifies the percentage of maximum allowed concurrent transfers reserved for destination XDP transfers
The following example displays SnapMirror options:
cluster1::> snapmirror set-options
      Percentage Reserved for DP Source Transfers:  0
     Percentage Reserved for XDP Source Transfers:  0
 Percentage Reserved for DP Destination Transfers:  0
Percentage Reserved for XDP Destination Transfers:  0
cluster1::> snapmirror set-options -dp-source-xfer-reserve-pct 25
     -xdp-source-xfer-reserve-pct 50  -dp-destination-xfer
     reserve-pct 0 -xdp-destination-xfer-reserve-pct 50
      Percentage Reserved for DP Source Transfers:  25
     Percentage Reserved for XDP Source Transfers:  50
Percentage Reserved for XDP Destination Transfers:  50
