snapmirror set-options
PDF of this doc site
Creating your file...
Your file is ready
Display/Set SnapMirror options
The snapmirror set-options
command can be used to display or set snapmirror options.
[-dp-source-xfer-reserve-pct {0|25%|50%|75%|100%}]
- Percentage Reserved for DP Source Transfers-
Specifies the percentage of maximum allowed concurrent transfers reserved for source DP transfers
[-xdp-source-xfer-reserve-pct {0|25%|50%|75%|100%}]
- Percentage Reserved for XDP Source Transfers-
Specifies the percentage of maximum allowed concurrent transfers reserved for source XDP transfers
[-dp-destination-xfer-reserve-pct {0|25%|50%|75%|100%}]
- Percentage Reserved for DP Destination Transfers-
Specifies the percentage of maximum allowed concurrent transfers reserved for destination DP transfers
[-xdp-destination-xfer-reserve-pct {0|25%|50%|75%|100%}]
- Percentage Reserved for XDP Destination Transfers-
Specifies the percentage of maximum allowed concurrent transfers reserved for destination XDP transfers
The following example displays SnapMirror options:
cluster1::> snapmirror set-options Percentage Reserved for DP Source Transfers: 0 Percentage Reserved for XDP Source Transfers: 0 Percentage Reserved for DP Destination Transfers: 0 Percentage Reserved for XDP Destination Transfers: 0 cluster1::> snapmirror set-options -dp-source-xfer-reserve-pct 25 -xdp-source-xfer-reserve-pct 50 -dp-destination-xfer reserve-pct 0 -xdp-destination-xfer-reserve-pct 50 cluster1::> snapmirror set-options Percentage Reserved for DP Source Transfers: 25 Percentage Reserved for XDP Source Transfers: 50 Percentage Reserved for DP Destination Transfers: 0 Percentage Reserved for XDP Destination Transfers: 50
