security login modify
Modify a login method
The security login modify command modifies the access-control role name of a login method. If the user is a member of multiple groups provisioned in the security login table, then the user will get access to a combined list of the commands authorized for the individual groups.
-vserver <Vserver Name>- Vserver-
This specifies the Vserver name of the login method.
-user-or-group-name <text>- User Name or Group Name-
This specifies the user name, Active Directory, LDAP, or NIS group name of the login method that is to be modified. A user name can be associated with multiple applications. If the user is a member of multiple groups provisioned in the security login table, then the user will get access to a combined list of the commands authorized for the individual groups.
-application <text>- Application-
This specifies the application of the login method. Possible values include console, http, ontapi, rsh, snmp, service-processor, ssh, and telnet.
-authentication-method <text>- Authentication Method-
This specifies the authentication method of the login method. Possible values include the following:
cert - SSL certificate authentication
community - SNMP community strings
domain - Active Directory authentication
nsswitch - LDAP or NIS authentication
password - Password
publickey - Public-key authentication
usm - SNMP user security model
saml - SAML authentication
[-remote-switch-ipaddress <IP Address>]- Remote Switch IP Address-
This specifies the IP address of the remote switch. The remote switch could be a cluster switch monitored by cluster switch health monitor (CSHM) or a Fibre Channel (FC) switch monitored by MetroCluster health monitor (MCC-HM). This parameter is applicable only when the application is
snmpand authentication method isusm(SNMP user security model). [-role <text>]- Role Name-
This modifies the access-control role name for the login method.
[-comment <text>]- Comment Text-
This specifies comment text for the user account, for example, "Guest account". The maximum length is 128 characters.
[-is-ns-switch-group {yes|no}]- Whether Ns-switch Group-
This specifies if
user-or-group-nameis an LDAP or NIS group. Possible values are yes or no. Default value is no. [-second-authentication-method {none|publickey|password}]- Second Authentication Method2-
This specifies the authentication method for the login method. It will be used as the second factor for authentication. Possible values include the following:
password - Password
none - default value
The following example illustrates how to modify a login method that has the user name guest , the application ontapi , and the authentication method password to use the access-control role guest for Vserver vs :
cluster1::> security login modify -user-or-group-name guest -application ontapi -authentication-method password -role guest -vserver vs
The following example illustrates how to modify a login method that has the user name guest , the application ssh , and the authentication method publickey to use the access-control role vsadmin for Vserver vs :
cluster1::> security login modify -user-or-group-name guest -application ssh -authentication-method publickey -role vsadmin -vserver vs
The following example illustrates how to modify a login method that has the group name nssgroup , the application ontapi , and the authentication method nsswitch to use the access-control role readonly for Vserver vs . Here is-ns-switch-group must be set to yes :
cluster1::> security login modify -user-or-group-name nssgroup -application ontapi -authentication-method nsswitch -role readonly -vserver vs -is-ns-switch-group yes
The following example illustrates how to modify a login method that has the user name guest , the application ssh , and the authentication method publickey to use the second-authentication-method password for Vserver vs :
cluster1::> security login modify -user-or-group-name guest -application ssh -authentication-method publickey -second-authentication-method password -vserver vs
The following example illustrates how to modify a login method to have individual authentication methods that have the user name guest , the application ssh , and the authentication method publickey to use the second-authentication-method none for Vserver vs :
cluster1::> security login modify -user-or-group-name guest -application ssh -authentication-method publickey -second-authentication-method none -vserver vs
