vserver show-aggregates
PDF of this doc site
Creating your file...
Show details of aggregates in a Vserver
The vserver show-aggregates
command displays the details of all the aggregates that are associated with Vservers. The aggregate details displayed are the aggregate name, state, available size, the type of aggregate and the SnapLock type.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Vserver-
If this optional parameter is specified, the command displays the details of aggregates that are associated with the specified Vserver.
[-aggregate <aggregate name>]
- Aggregate-
If this optional parameter is specified, the command displays all of the Vservers configured with the specified aggregate.
The following example displays the aggregates configured for Vserver vs.
cluster1::> vserver show-aggregates -vserver vs Available Vserver Aggregate State Size Type SnapLock-Type -------------- -------------- ------- ---------- ------- ------------- vs aggr1 online 795.2MB hdd non-snaplock vs aggr2 online 795.2MB hdd non-snaplock 2 entries were displayed.
