volume snapshot prepare-for-revert
Deletes multiple Snapshot copies of the current File System version.
This command will delete all Snapshot copies that have the format used by the current version of Data ONTAP. It will fail if any Snapshot copy polices are enabled, or if any Snapshot copies have an owner.
Snapshot policies must be disabled prior to running this command. |
-node <nodename>
- Node-
The name of the node.
The following example prepares the Snapshot copies for revert.
cluster1::*> volume snapshot prepare-for-revert -node node1
