Command reference
volume snapshot prepare-for-revert
Deletes multiple Snapshot copies of the current File System version.
This command will delete all snapshots that have the format used by the current version of ONTAP. It will fail if snapshot polices are enabled, or if snapshots have an owner.
Note Snapshot policies must be disabled prior to running this command.
-node <nodename> - Node (privilege: advanced)
The name of the node.
The following example prepares the snapshots for revert.
cluster1::*> volume snapshot prepare-for-revert -node node1
