storage pool show-aggregate
Display aggregates provisioned from storage pools
The storage pool show-aggregate command displays allocation information for SSD storage pools in the cluster. The command output depends upon the parameter or parameters specified with the command. If no parameters are specified, the command displays information about allocations of all storage pools in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-storage-pool <storage pool name>]- Name of Storage Pool-
Selects the storage pools that match this parameter value.
[-aggregate <aggregate name>]- Aggregate-
[-capacity {<integer>[KB|MB|GB|TB|PB]}]- Capacity-
Capacity includes space provided by data and parity portions of each allocation unit. Only the data portions of each allocation unit contribute to the cache or usable capacity of Flash Pool.
[-allocated-unit-count <integer>]- Number of AU's Assigned to This Aggregate-
[-original-owner <text>]- Original Owner Name-
[-node {<nodename>|local}]- Node-
Display information about the aggregate or aggregates using a storage pool called SP2 :
cluster1::> storage pool show-aggregate -storage-pool SP2 -instance
Name of Storage Pool: SP2
Aggregate: node2_flashpool_1
Capacity: 744.9GB
Number of AU's Assigned to This Aggregate: 1
Original Owner Name: node2
Node: node2
