metrocluster transition disable
Disable Transition
The metrocluster transition disable command is used to end the transition from a MetroCluster FC to a MetroCluster IP configuration. The command clears the setting for transition mode on the local and partner clusters.
The following example shows how to disable the transition mode:
clusA::> metrocluster transition disable clusA::> metrocluster transition show-mode Transition Mode -------------------------- not-enabled
