ONTAP commands
metrocluster transition disable
Disable Transition
The metrocluster transition disable command is used to end the transition from a MetorCluster FC to a MetroCluster IP configuration. The command clears the setting for transition mode on the local and partner clusters.
The following example shows how to disable the transition mode:
clusA::> metrocluster transition disable
clusA::> metrocluster transition show-mode
 Transition Mode
 not-enabled
