Command reference
security session limit application create
Create per-application session limit
This command allows creation of a per-application management session limit that does not yet exist.
-interface {cli|ontapi|rest} - Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-application <text> - Application (privilege: advanced)
The specified application to which this limit applies. The limit with the application name -default- is the limit used for any application without a specific configured limit.
-max-active-limit <integer> - Max-Active Limit (privilege: advanced)
The maximum number of concurrent sessions allowed for this interface and application.
The following example illustrates creating a limit for management sessions from a custom application.
cluster1::*> security session limit application create -interface ontapi -application "custom_app" -max-active-limit 8
